Maximize your creativity and your desk space, too. Small enough to fit almost anywhere, the compact Aspire X series is much smaller than a tower PC, yet offers plenty of power and performance for your multimedia creativity and entertainment.
Fits in well
Easy to place, easy to set up: Whether on a bookcase shelf, in a corner of your desk, or tucked underneath, this compact PC just fits. It's perfect for storing movies and media, as a gaming or learning machine in the kids' room, or as a homework tool for students in cramped dorms. -
Full power
Finish tasks, watch video, play casual games, and keep in touch with friends - all easy with the advanced processor and outstanding display graphics. -
Multimedia experience
Wonderfully compact - and greatly entertaining - the Aspire X series is your high-definition multimedia center. Enjoy vividly accurate color and sound. Plus, you can easily take the multimedia experience to your big screen, thanks to the built-in HDMI port. -
Expandable
Add memory for fast response in entertainment, gaming and design applications. Easily transfer media from your digital devices using the front-mounted card reader or speedy USB ports.
- Acer Aspire XC-710_W - SFF - Core i5 6400 2.7 GHz - 8 GB - SSD 128 GB, HDD 1 TB
- Personal computer - small form factor
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i5 (6th Gen) 6400 / 2.7 GHz (, up to 3.3 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB L3 Cache
- Cache Per Processor
- 6 MB
- RAM
- 8 GB DDR3L SDRAM
- Storage Controller
- SATA
- Hard Drive
- SSD 128 GB - SATA 6Gb/s - M.2
- Hard Drive (2nd)
- HDD 1 TB - SATA - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- Graphics Controller
- NVIDIA GeForce GTX 745
- Video Memory
- 4 GB
- Audio Output
- 5.1 channel surround
- Networking
- GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
- Power
- AC 230V
- OS Provided
- Windows 10 Home 64-bit Edition
- 10 cm x 39.77 cm x 27.75 cm
- 5.25 kg
- Personal computer
- Product Form Factor
- Small form factor
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.7 GHz
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- L3 Cache - 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- DIMM 240-pin
- Slots
- 2 (Total) / 0 (empty)
- Unbuffered
- Configuration Features
- 2 x 4 GB
Hard Drive
- SSD - M.2
- Capacity
- 1 x 128 GB
- Interface Type
- SATA 6Gb/s
Hard Drive (2nd)
- HDD
- Interface Class
- Serial ATA
- Capacity
- 1 x 1 TB
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Memory
- 4 GB
- Video Interfaces
- DVI, HDMI
Audio Output
- Sound Output Mode
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 3165
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- Bays
- External 5.25" , Internal 3.5"
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 0 (free) x DIMM 240-pin
- 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 (2 front, 2 rear) , 2 x audio line-in/microphone (1 front, 1 rear) , 2 x audio line-out/headphones (1 front, 1 rear) , 1 x audio line-in , 1 x HDMI , 1 x DVI-I
- Included Accessories
- Wireless antenna
- BSMI, CB, FCC, RoHS, PC 2001
- Power supply
- Voltage Required
- AC 230V
- Power Provided
- 220 Watt
- Efficiency
- 82%+
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- 10 cm
- 39.77 cm
- 27.75 cm
- 5.25 kg
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.86 |
