The KA series is optimized for a comfortable viewing experience. The display is easy on the eyes with low response times and special technology to reduce glare and harsh blue light. Easy adjustments and a wide viewing angle help you find the perfect position.
- Acer KA270H - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class F
- Energy Consumption per Year
- 59 kWh
- Power Consumption (On mode)
- 26.1 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 64 cm x 20 cm x 47.89 cm
- Localisation
- Italy
- Microsoft Certification
- Compatible with Windows 7
- MPR II, FCC Part 15, WEEE, DDC-2B/CI, Directive 2009/125/EC, EN 50564:2011, Directive 1275/2008/EC, EN61000-3-3:2008, RoHS 2011/65/EU, EMC 2004/108/EC, LVD 2006/95/EC, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN50581:2012, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011, IEC 62301:2011, EN 55024:2010, EN 55022:2010 Class B
- 3-year warranty
- Display Type
- Energy Class
- Class F
- 59 kWh
- Diagonal Size
- 27"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 4 ms
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, input select, clock, focus, blue reduction
- eColor Management, Acer Adaptive Contrast Management (ACM), Acer Empowering Technology, Transition Minimised Differential Signaling (TMDS) technology
- Black
- 64 cm x 20 cm x 47.89 cm - with stand
- VGA , DVI , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable
- Localisation
- Italy
- Security Slot Type
- Kensington security slot
- Input Voltage
- 26.1 W
- Power Consumption SDR (On mode)
- 26.1 kWh/1000h
- Power Consumption (Typical)
- 25.8 Watt
- Power Consumption Stand by
- 450 mW
- Power Consumption Sleep
- 350 mW
- Dimensions & Weight Details
- With stand - width: 64 cm - depth: 20 cm - height: 47.89 cm , Without stand - width: 64 cm - depth: 6.2 cm - height: 38.1 cm
- Limited warranty - 3 years
