Acecad A4 Digimemo digital notepad
Quicklinx: 48CHWS00 Mfr#: DIGIM-A402
The DigiMemo A402 provides a digital record of any notes or drawings that are made on A4 paper. Accepting normal A4 pads and being not much larger than the pad itself it can be used anywhere a normal pad would. Used by surveyors, doctors, teachers... anyone making notes anywhere. It is the perfect digital assistant.
  • Take notes
    Place any ordinary paper or notepad on the digital pad. Write on the paper with the digital inking pen. The digital pad digitally records anything you write in its built-in storage device or an optional SD card in real time. One page you write is stored as one digital page.
  • Organize your notes
    With its DigiMemo Manager software, you can easily view, edit and organize your digital pages in Windows. You also can use the on-line writing function which can instantly synchronize your writing on the paper with the digital page in its software. Save any digital pages you arbitrarily select as a book file (e-Book).
Acecad DigiMemo A402 - digital notepad - USB
Digital notepad
Wired - USB
24.5 cm x 1.2 cm x 33.6 cm
0.62 kg
Movement Detection Technology
Electromagnetic
Supported Flash Memory
SD Memory Card
1 x USB cable
4 x AAA type
Microsoft Windows 2000, Microsoft Windows XP
Digital notepad
24.5 cm
1.2 cm
33.6 cm
0.62 kg
Input Device
Wired
USB
Electromagnetic
32 MB
Active Area
21 cm x 27.9 cm
1 x USB
SD Memory Card
Electronic pen, 2 ink cartridges
1 x USB cable
AAA type
Installed Qty
4
Run Time (Up To)
100 hour(s)
Additional Requirements
CD-ROM, USB port
System Requirements Details
Pentium III - 500 MHz - RAM 128 MB - HD 32 MB
