Accuratus Toughball 2 - 2.4GHz Wireless Multimedia Keyboard
Quicklinx: 9YWGWS00 Mfr#: KYB-TOUGHBALL2
Type: Keyboard
Wired / Wireless: Wireless
Compatibility: Mac, PC
£44.76 ex VAT
£53.71 inc VAT
Toughball 2, beautiful close up, even better from a distance... From its special coating to its pin sharp optical trackball, the Toughball 2 is a product of beauty. Hook the Toughball up to a PC with an LCD projector and be staggered at its wireless range. Use it with your media center and realize it works from all corners of the room or simply use it as a solid workhorse in the office. Either way the Toughball 2 will not disappoint.
Comfortable on and off the desk... Sooner or later you will want to sit back at your desk - only then will you appreciate the sculptured underside and newly designed contoured thumb areas. Its subtle curves will lock the keyboard on your lap making it far easier to work with than most flat keyboards. The Toughball 2 has a high resolution stainless steel trackball giving a very precise, extremely durable and reliable mouse movement.
Accuratus Toughball 2 - keyboard - QWERTY - UK
Keyboard
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Internet browsing, multimedia, My Computer, e-mail, volume, mute, mouse buttons, Windows 8
Integrated optical trackball, battery LED indicator, sleep mode
34.4 cm x 16.2 cm x 4.75 cm
600 g
Keyboard
2.4 GHz
Max Operating Distance
Up to 15 m
Wireless Receiver
Input Device
Wireless
Hot Keys Function
QWERTY UK
34.4 cm
16.2 cm
4.75 cm
600 g
Plug and Play, FCC, RoHS, WEEE
Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
AA type
Installed Qty
2
Type: Keyboard
Compatibility: Mac
Compatibility: PC
Brand: Accuratus
