Toughball 2, beautiful close up, even better from a distance... From its special coating to its pin sharp optical trackball, the Toughball 2 is a product of beauty. Hook the Toughball up to a PC with an LCD projector and be staggered at its wireless range. Use it with your media center and realize it works from all corners of the room or simply use it as a solid workhorse in the office. Either way the Toughball 2 will not disappoint.
Comfortable on and off the desk... Sooner or later you will want to sit back at your desk - only then will you appreciate the sculptured underside and newly designed contoured thumb areas. Its subtle curves will lock the keyboard on your lap making it far easier to work with than most flat keyboards. The Toughball 2 has a high resolution stainless steel trackball giving a very precise, extremely durable and reliable mouse movement.
- Accuratus Toughball 2 - keyboard - QWERTY - UK
- Keyboard
- Interface
- 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Internet browsing, multimedia, My Computer, e-mail, volume, mute, mouse buttons, Windows 8
- Integrated optical trackball, battery LED indicator, sleep mode
- 34.4 cm x 16.2 cm x 4.75 cm
- 600 g
- Keyboard
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 15 m
- Wireless Receiver
Input Device
- Wireless
- Hot Keys Function
- QWERTY UK
- 34.4 cm
- 16.2 cm
- 4.75 cm
- 600 g
- Plug and Play, FCC, RoHS, WEEE
- OS Required
- Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
- AA type
- Installed Qty
- 2
