3M Privacy Filter for 22" Monitors 16:10 - display privacy filter - 22" wide
Quicklinx: D5SPWS00 Mfr#: PF220W1B
Accessory Type: Privacy Screen
£69.38 ex VAT
£83.25 inc VAT
Display and device technology continues to advance. So do we. Behind the simplicity of our products is a powerful combination of optical science and sheer ingenuity you’ve come to expect from 3M. The microlouver technology in our world-class privacy filter helps protect the confidential and sensitive information displayed on your monitor from the side-views of visual hackers. The matte surface helps reduce glare and hide fingerprints, so you get crisp image clarity on your screen, while visual hackers with side views are kept in the dark.
  • Enhanced privacy
    Equipped with Micro-Louver technology, the 3M Privacy Filter for 22" Monitors 16:10 ensures that your data remains private. The technology allows only the person directly in front of the monitor to see the screen clearly, while people at side angles see a darkened screen.
  • Versatile viewing
    This privacy filter offers a reversible feature, providing the flexibility to choose between a glossy or matte finish. The matte finish reduces glare and reflections, making it easier to see your screen in brightly lit environments.
  • Durable design
    Designed with scratch-resistant technology, the filter protects your screen from dust, scratches, and smudges. This prolongs the life of your monitor and maintains clear visibility of your display.
  • Easy installation
    The package includes adhesive strips and slide mounts, allowing for a quick and secure installation of the privacy filter on your 22" monitor. The frameless design seamlessly integrates with your monitor, maintaining its sleek aesthetic.
3M Privacy Filter display privacy filter - 22"
Display privacy filter
Package Content
Adhesive strips, slide mounts
Display Screen Size Compatibility
22"
47.4 cm 29.7 cm
1-year warranty
Package Content
22"
47.4 cm 29.7 cm
Display Filter
Viewing Area Height
29.7 cm
Viewing Area Width
47.4 cm
Aspect Ratio
16:10
Surface Finish
Glossy/matte
Scratch Resistant
Frameless, landscape mounting, 60° viewing, reversible, Micro-Louver technology, anti-glare
Limited warranty - 1 year
Brand: 3M
