3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit standard laptops with a diagonally measured 12 3/16" viewing screen and a 4:3 aspect ratio. Actual filter dimensions are 9 3/4" wide x 7 5/16" high (247 mm x 186 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas such as airports, airplanes, commuter trains, coffee shops and other public places. Limited 1-year warranty.
- 3M PF12.1 - notebook privacy filter
- Product Type
- Notebook privacy filter
- 24.7 cm 18.6 cm
- Display Screen Size Compatibility
- 12.1"
- Anti-reflective
- 1 year warranty
- Product Type
- 24.7 cm
- 18.6 cm
- 12.1"
- Anti-reflective
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year
