3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 27 1/16" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 22 15/16" wide x 14 5/16" high (582 mm x 364 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments. Limited 1-year warranty.
- 3M PF27.0W - display privacy filter - 27" wide
- Product Type
- Display privacy filter
- Display Screen Size Compatibility
- 27" wide
- 58.2 cm 36.4 cm
- 1 year warranty
- Product Type
- 27" wide
- 58.2 cm 36.4 cm
- Anti-reflective, easy-to-remove
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year
