The 3M MicroTouch Display M1700SS (17"), a purpose-built, surface capacitive touch display, provides a cost-competitive touch alternative to 5-wire resistive display solutions.
The display offers a stable base, highly durable touch screen, brilliant optics and a hidden cable management system, all in an elegant and simple-to-use design. This display easily integrates into numerous point-of-sale, PC, and thin client systems making it ideal for applications requiring long life and 24/7 uptime.
The M1700SS uses the 3M MicroTouch ClearTek II system which provides superior optics, durability from contaminants like dust, liquid and grime and speed for high transaction based environments.
- 3M MicroTouch M1700SS Serial - LCD monitor - 17"
- LCD monitor - 17" - touchscreen
- Touch-screen
- Native Resolution
- 1280 x 1024 at 60 Hz
- Pixel Pitch
- 0.264 mm
- Brightness
- 270 cd/m²
- Contrast Ratio
- 800:1
- Response Time
- 9 ms
- Colour Support
- 16.2 million colours
- Input Connectors
- DVI-D, VGA
- Black
- 40.5 cm x 24.7 cm x 41.3 cm
- 8.6 kg
- FCC Class B certified, UL, C-Tick, cUL, VESA DPMS, CCC, RoHS
- 3 years warranty
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 17"
- Native Resolution
- Pixel Pitch
- 0.264 mm
- Brightness
- 270 cd/m²
- Contrast Ratio
- 800:1
- Colour Support
- Response Time
- 9 ms
- Horizontal Viewing Angle
- +80 / -80
- Vertical Viewing Angle
- +80 / -80
- Controls & Adjustments
- Brightness, contrast, H/V position, colour balance, phase, clock
- Black
- 8.6 kg
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Capacitive
- VGA , Serial , DVI-D
Mechanical
- Flat Panel Mount Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x serial cable
- Backlight Life
- 40,000 hours
- Power Supply
- External
- 40 Watt
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80%
