This mouse is clinically proven to alleviate pain and discomfort of repetitive stress injuries in the hand, wrist or arm associated with the use of traditional mice - which requires forearm pronation and may cause pressure on the wrist and carpal tunnel area. The 3M Ergonomic Mouse has earned an ease-of-use commendation from the arthritis foundation for its patented, vertical grip design that keeps your hand and wrist at a neutral angle, while the mouse works as a regular optical mouse. Grip the handle and rest your hand on the base.
- 3M Ergonomic Mouse EM550GPL Large - mouse
- Mouse
- Connectivity Technology
- Wireless
- 14 cm x 14 cm x 13.3 cm
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- 2-year warranty
- Mouse
- Wireless Receiver
- 14 cm
- 14 cm
- 13.3 cm
Input Device
- Wireless
- Optical
- Buttons Qty
- 3
- 1 x USB - 4 pin USB Type A
- Plug and Play
- Software Included
- Drivers & Utilities
- Limited warranty - 2 years
