3M Ergo Wireless EM550GPS Mouse
Quicklinx: 6LXKWS00 Mfr#: EM550GPS
The 3M Ergonomic Mouse has earned an ease-of-use commendation from the Arthritis Foundation for its patented, vertical grip design that keeps your hand and wrist at a neutral angle, while the mouse works as a regular optical mouse. Grip the handle and rest your hand on the base. Use your thumb to left and right click. It is wireless and USB compatible plug and play and features optical sensor.
3M Ergonomic Mouse EM550GPS Small - mouse - black
Mouse
Wireless
Orientation
Right-handed
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
On/off power switch
2 x AAA type
Linux, Apple MacOS X 10.4.x, Microsoft Windows Vista / XP, Apple MacOS X 10.5.x
Mouse
Wireless Receiver
Orientation
Right-handed
Input Device
Wireless
Optical
Buttons Qty
3
On/off power switch
1 x USB - 4 pin USB Type A
Plug and Play
AAA type
Installed Qty
2
