3M Easy-On Privacy Filters allow you to view your tablet in public without revealing confidential information. Bubble-free adhesive allows the privacy filter to be quickly and easily applied and reapplied numerous times. Custom fit to your Microsoft Surface RT/Pro/Pro 2. Privacy in landscape; change device orientation to share. Lightweight, thin, frameless design. Privacy filter protects your display from scratches and the rigors of daily use. Both the privacy filter and adhesive corner tabs are washable to remove any dirt or debris. Will not affect touchscreen functionality. Includes a convenient storage folder that keeps your privacy filter clean while not in use on your device. Great for high traffic areas such as airports, airplanes, commuter trains, coffee shops and other public places.
- 3M Easy-On Privacy Filter - screen privacy filter (landscape) for tablet
- Product Type
- Screen privacy filter (landscape)
- Intended For
- Tablet
- Protection
- Scratch-resistant, dirt-resistant
- Package Content
- Privacy screen protector, storage folder, adhesive corner tabs
- Designed For
- Microsoft Surface Pro, Pro 2, RT
- Product Type
- Intended For
- Tablet
- Protection
- Package Content
- Scratch Resistant
- Washable, clean-edge technology, residue free
- Designed For
