3M Anti-Glare Filters help reduce glare and mirror-like reflections. Its lightweight, thin, frameless design is easily applied and reapplied numerous times with no bubbles. Designed to fit widescreen desktop LCD monitors with a diagonally measured 23" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 20 1/16" wide x 11 5/16" high (510 mm x 287 mm). Protects screen against scratches. Attaches with optically clear adhesive strips that can easily be applied and reapplied numerous times. Easy to clean; includes cleaning cloth. Compatible with most touchscreen displays.
- 3M Anti-Glare Filter AG23.0W9 - display screen filter - 23" wide
- Product Type
- Display screen filter
- Package Content
- Cleaning cloth
- Clear
- Display Screen Size Compatibility
- 23" wide
- 1 year warranty
- Product Type
- Package Content
- Cleaning cloth
- 23" wide
- Clear
Monitor Filter
- Viewing Area Height
- 28.7 cm
- Viewing Area Width
- 51 cm
- Aspect Ratio
- 16:9
- Scratch Resistant
- Frameless
- Anti-glare, anti-reflective
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year
