3M Anti-Glare Filter 23" Frameless
Quicklinx: 9XYPWS00 Mfr#: AG23.0W9
3M Anti-Glare Filters help reduce glare and mirror-like reflections. Its lightweight, thin, frameless design is easily applied and reapplied numerous times with no bubbles. Designed to fit widescreen desktop LCD monitors with a diagonally measured 23" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 20 1/16" wide x 11 5/16" high (510 mm x 287 mm). Protects screen against scratches. Attaches with optically clear adhesive strips that can easily be applied and reapplied numerous times. Easy to clean; includes cleaning cloth. Compatible with most touchscreen displays.
3M Anti-Glare Filter AG23.0W9 - display screen filter - 23" wide
Display screen filter
Package Content
Cleaning cloth
Clear
Display Screen Size Compatibility
23" wide
1 year warranty
Package Content
Cleaning cloth
23" wide
Clear
Monitor Filter
Viewing Area Height
28.7 cm
Viewing Area Width
51 cm
Aspect Ratio
16:9
Scratch Resistant
Frameless
Anti-glare, anti-reflective
1 year warranty
Service & Support Details
Limited warranty - 1 year
