3M Anti-Glare Filters help reduce glare and mirror-like reflections. Its lightweight, thin, frameless design is easily applied and reapplied numerous times with no bubbles. Designed to fit widescreen desktop LCD monitors with a diagonally measured 23" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 20 1/16" wide x 11 5/16" high (510 mm x 287 mm). Protects screen against scratches. Attaches with optically clear adhesive strips that can easily be applied and reapplied numerous times. Easy to clean; includes cleaning cloth. Compatible with most touchscreen displays.
- 3M Anti-Glare Filter AG23.0W9 - display screen filter - 23" wide
- Product Type
- Display screen filter
- Package Content
- Cleaning cloth
- Clear
- Display Screen Size Compatibility
- 23" wide
- 1 year warranty
- Product Type
- Package Content
- Cleaning cloth
- 23" wide
- Clear
Monitor Filter
- Viewing Area Height
- 28.7 cm
- Viewing Area Width
- 51 cm
- Aspect Ratio
- 16:9
- Scratch Resistant
- Frameless
- Anti-glare, anti-reflective
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £96.99 | in stock |
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
9XYP 033721 Condition: Customer return - item has been opened but is in excellent condition |
£10.09 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
