3M 25" Widescreen Monitor Privacy Filter - Frameless
Quicklinx: FJGJWS00 Mfr#: PF250w9b
£89.02 ex VAT
£106.82 inc VAT
3M Black Privacy Filters for monitors provide world-class "black out" privacy from side views, while creating an excellent, high-resolution viewing experience. Reversible between a glossy side and a glare-reducing matte side that helps reduce reflections and hide fingerprints, so you can enjoy pristine image clarity.
  • Enhanced privacy
    Equipped with Micro-Louver technology, the 3M Privacy Filter for 25" Monitors 16:9 ensures that your information remains confidential, offering a 60° viewing angle that keeps your data visible only to you.
  • Versatile viewing
    This privacy filter offers a glossy/matte surface finish, allowing you to choose between a clearer or glare-reduced viewing experience. Its reversible feature means you can switch between finishes to suit your viewing preferences.
  • Durable design
    Designed to be scratch resistant, the 3M Privacy Filter protects your screen from everyday scratches and dust, maintaining the pristine condition of your monitor.
  • Easy installation
    With adhesive strips and slide mounts included in the package, the privacy filter is easy to install and fits perfectly on 25" wide monitors, providing a frameless, seamless look for your device.
3M Privacy Filter display privacy filter - 25"
Display privacy filter
Package Content
Adhesive strips, slide mounts
Display Screen Size Compatibility
25"
1-year warranty
Package Content
25"
Display Filter
Viewing Area Height
31.2 cm
Viewing Area Width
55.4 cm
Aspect Ratio
16:9
Surface Finish
Glossy/matte
Scratch Resistant
Frameless, landscape mounting, 60° viewing, reversible, Micro-Louver technology, anti-glare
Limited warranty - 1 year
Brand: 3M
