3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 24 1/8" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 20 7/16" wide x 12 3/4" high (519 mm x 325 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
- 3M PF24.0W - display privacy filter - 24" wide
- Product Type
- Display privacy filter
- Display Screen Size Compatibility
- 24" wide
- 1 year warranty
- Product Type
- 24" wide
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year
