3M 24" Widescreen Display Privacy Filter
Quicklinx: 92MWWS00 Mfr#: PF24.0W9
Accessory Type: Privacy Screen
19 In Stock
£84.81 ex VAT
£101.77 inc VAT
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 24" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 20 15/16" wide x 11 13/16" high (532 mm x 299 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
3M PF24.0W9 - display privacy filter - 24" wide
Display privacy filter
Display Screen Size Compatibility
24" wide
53.2 cm 29.8 cm
1 year warranty
24" wide
53.2 cm 29.8 cm
1 year warranty
Service & Support Details
Limited warranty - 1 year
Brand: 3M
