3M 23.6" Widescreen (16:9) Monitor Privacy Filter - Frameless
Quicklinx: 9ZBQWS00 Mfr#: PF23.6W9
£69.04 ex VAT
£82.84 inc VAT
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 23 9/16" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 20 9/16" wide x 11 9/16" high (522 mm x 294 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
3M PF23.6W9 - display privacy filter - 23.6" wide
Display privacy filter
Display Screen Size Compatibility
23.6" wide
52.2 cm 29.4 cm
1 year warranty
23.6" wide
52.2 cm 29.4 cm
1 year warranty
Service & Support Details
Limited warranty - 1 year
Brand: 3M
