3M 22" Wide LCD Privacy Filter
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: 5CDQWS00 Mfr#: PF22.0W
Accessory Type: Privacy Screen
Stock Status: In Stock, Used Stock
15 in stock
£66.99 ex VAT
£80.38 inc VAT
Standard delivery Delivered within 3-5 working days
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 22" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 18 11/16" wide x 11 11/16" high (474 mm x 297 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
3M Privacy Filter for 22" Widescreen Monitor - display privacy filter - 22" wide
Display privacy filter
Display Screen Size Compatibility
22" wide
47.4 cm 29.7 cm
1-year warranty
22" wide
47.4 cm 29.7 cm
Monitor Filter
Viewing Area Height
29.7 cm
Viewing Area Width
47.4 cm
Aspect Ratio
16:10
Surface Finish
Matte
Scratch Resistant
Frameless
Anti-glare, anti-reflective, reversible, frameless
Limited warranty - 1 year
3M 22 Bundle deal on 3M 22" Wide LCD Privacy Filter
£166.16
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 5CDQ 033550
Condition: Damaged stock - Item is new but has packaging damage
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £13.64
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: 3M
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
