3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 22" viewing screen and a 16:10 aspect ratio. Actual filter dimensions are 18 11/16" wide x 11 11/16" high (474 mm x 297 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
- 3M Privacy Filter display privacy filter - 22"
- Product Type
- Display privacy filter
- Black
- Display Screen Size Compatibility
- 22"
- 47.4 cm 29.7 cm
- 1-year warranty
- Product Type
- 22"
- 47.4 cm 29.7 cm
- Black
Display Filter
- Viewing Area Height
- 29.7 cm
- Viewing Area Width
- 47.4 cm
- Aspect Ratio
- 16:10
- Surface Finish
- Matte
- Scratch Resistant
- Frameless
- Anti-glare, anti-reflective, reversible, frameless
- Limited warranty - 1 year
3M 22" Wide LCD Privacy Filter
