3M 20" Desktop Privacy Filter Frameless Widescreen
Quicklinx: 8V1SWS00 Mfr#: PF20.0W9
Accessory Type: Privacy Screen
£63.11 ex VAT
£75.73 inc VAT
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 20" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 17 7/16" wide x 9 13/16" high (443 mm x 250 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
3M Privacy Filter PF20.0W9 - display screen filter - 20" wide
Display screen filter
Display Screen Size Compatibility
20" wide
44.3 cm 24.9 cm
1 year warranty
20" wide
44.3 cm 24.9 cm
Monitor Filter
Scratch Resistant
1 year warranty
Service & Support Details
Limited warranty - 1 year
Brand: 3M
