3M 19.5" Widescreen Monitor Privacy Filter - Frameless
Quicklinx: 9ZBBWS00 Mfr#: PF19.5W9
Device Type: Laptop
Type: Privacy Screen
Device Screen Size: 19
Colour: Clear
£61.42 ex VAT
£73.70 inc VAT
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit widescreen desktop LCD monitors with a diagonally measured 19 1/2" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 17" wide x 9 5/16" high (433 mm x 237 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
3M Privacy Filter PF19.5W9 - display privacy filter
Display privacy filter
Display Screen Size Compatibility
19.5"
19.5"
Device Type: Laptop
Colour: Clear
Brand: 3M
