3M 19" TFT Privacy Screen
Quicklinx: 588TWS00 Mfr#: PF19.0
Accessory Type: Privacy Screen
More than 50 in stock
£48.96 ex VAT
£58.75 inc VAT
3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Designed to fit standard desktop LCD monitors with a diagonally measured 19" viewing screen and a 5:4 aspect ratio. Actual filter dimensions are 14 13/16" wide x 11 7/8" high (377 mm x 302 mm). Includes your choice of two easy-to-use attachment methods. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Great for high traffic areas and open office environments.
3M Privacy Filter PF19.0 - display privacy filter - 19"
Display privacy filter
Display Screen Size Compatibility
19"
Product Material
Plastic
37.7 cm x 30.2 cm
1 year warranty
19"
Product Material
Plastic
37.7 cm - 30.2 cm
Monitor Filter
Scratch Resistant
Double-sided
Flame retardant
1 year warranty
Service & Support Details
Limited warranty - 1 year
Brand: 3M
Stock Status: In stock
