3M Framed Desktop Monitor Privacy Filters offer outstanding privacy protection; allowing only those directly in front of the monitor to see on-screen data. Anti-reflective surface reduces screen glare. Fits 16" to 17" CRT monitors and 17" widescreen LCD desktop monitors. Actual filter viewing area dimensions are 14 15/16" wide x 9 1/2" high (379mm x 242mm). Two easy-to-use attachment methods - 3M Command adhesive and attachable hanger arms. Helps protect the display from scratches and fingerprints. Easy to clean surface is smudge-resistant and repels permanent marker.
- 3M Lightweight LCD Privacy Filter PF317W - display privacy filter - 17" wide
- Product Type
- Display privacy filter
- Black
- Display Screen Size Compatibility
- 17" wide
- 41.4 cm x 1 cm x 26.3 cm
- 1 year warranty
- Product Type
- 17" wide
- 41.4 cm - 1 cm - 26.3 cm
- Black
- Anti-glare, anti-reflective
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year
