3M Privacy Filters keep confidential information private. Only persons directly in front of the monitor can see the image on screen; others on either side of them see a darkened screen. Custom fit to your Apple MacBook Pro 15-inch with Retina display. The filter application system features an optically clear adhesive designed specifically for display screens. Testing proves that, when kept clean, the filter can be repositioned hundreds of times. Reversible, matte side reduces glare and reflections. Lightweight, thin, frameless design. Protects display from dirt, debris and scratches. Cleans easily with a soft cloth and water. Includes a convenient storage folder that keeps your privacy filter clean while not in use on your device. Great for high traffic areas such as airports, airplanes, commuter trains, coffee shops and other public places.
- 3M Privacy Filter PFMR15 - notebook privacy filter
- Product Type
- Notebook privacy filter
- Display Screen Size Compatibility
- 15"
- Anti-glare, anti-reflective
- 1 year warranty
- Designed For
- Apple MacBook Pro with Retina display (15.4 in)
- Product Type
- 15"
Monitor Filter
- Aspect Ratio
- 16:10
- Surface Finish
- Matte
- Frameless
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year
- Designed For
