Features include second generation QuickView Navigation technology, dual-function Intelligent Function keys and at-a-glance access to important information via the full-color LCD Workflow Assistant.
Design excellence for engineers
The challenges for today's CAD-intensive business are many. The demand for more advanced products, a compressed time to market and the focus on more efficient development cycles all place increased performance demands on the CAD professional. SpacePilot PRO is engineered to meet these challenges and to excel in today's most demanding 3D software environments. -
LCD workflow assistant
The full-color LCD delivers at-a-glance visibility of e-mail, tasks, calendar entries and function key commands ensuring quick access to key information without interrupting your workflow. -
Powerful application control
Five fully customizable, dual-function intelligent function keys provide instant access to 10 frequently used commands. SpacePilot PRO recognizes the active application and work environment and automatically assigns the appropriate commands. The color LCD provides visual feedback on function key assignment ensuring an optimized workflow. -
Advanced MCAD navigation
SpacePilot PRO features the most advanced six-degrees-of-freedom (6DoF) sensor technology. Gently push, pull, twist or tilt the compact controller cap to smoothly pan, zoom and rotate 3D models. It's like reaching into the screen and holding the model in your hand. The second generation QuickView navigation keys provide fingertip access to 32 standard views giving an unparalleled level of control that encourages model exploration leading to improved error detection and design quality. -
Superior comfort
The soft coated, sculpted wrist rest positions the hand perfectly while the compact controller cap guides your fingers into the ideal position for precise and effortless control. The most frequently used function keys are conveniently positioned, ensuring a comfortable working experience, even for the longest design sessions.
- 3Dconnexion SpacePilot PRO - 3D mouse - USB
- 3D mouse
- Connectivity Technology
- Wired - USB
- 15 cm x 23.1 cm x 5.8 cm
- 0.88 kg
- Buttons Qty
- 31
- Programmable buttons, LCD screen
- OS Required
- Microsoft Windows 2000, IBM AIX 5.2, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Red Hat Enterprise Linux WS 3, SunSoft Solaris 8 or later, HP-UX 11, SuSE Linux 9.0 or later, Microsoft Windows Vista, Microsoft Windows Vista (64-bit versions)
- 3-year warranty
- 3D mouse
- 15 cm
- 23.1 cm
- 5.8 cm
- 0.88 kg
Input Device
- Wired
- Interface
- USB
- Buttons Qty
- 31
- 1 x USB - 4 pin USB Type A
- TUV, VCCI, C-Tick, BSMI, GOST, cUL, RRL, WHQL, FCC Part 15 B, WEEE
- Software Included
- Drivers & Utilities
- OS Required
- Additional Requirements
- CD-ROM
- Limited warranty - 3 years
