3Dconnexion SpaceMouse Enterprise 3D Mouse 31 Buttons Wired USB
Quicklinx: CVKSWS00 Mfr#: 3DX-700056
Type: Mouse
Wired / Wireless: Wired
Hurry, only 3 left in stock!
£405.54 ex VAT
£486.64 inc VAT
It's easier than ever to view your 3D models with SpaceMouse Enterprise's 6-Degrees-of-Freedom (6DoF) sensor and instant access to Standard and Custom Views. Gentle manipulation of the controller cap translates to smooth and intuitive 3D navigation, while a press of a finger snaps your model to a standard view of your choice. The addition of three Custom View keys makes for an unequaled 3D navigation experience.
  • SpaceMouse Enterprise – Built for Prime Engineering Performance
    CAD experts demand the highest level of performance in their daily-use work devices. In professional environments where quality output means everything, SpaceMouse Enterprise is the cornerstone for any engineering team, architectural design firm, development stable and more.
  • Real-Time 3D Engineering
    View 3D models with 3Dconnexion's 6-Degrees-of-Freedom (6DoF) sensor, allowing precision manipulation of digital content and camera positions in CAD applications by gently pushing, pulling, twisting or tilting the controller cap to pan, zoom, and rotate 3D drawings. This leaves the other hand free to simultaneously use a regular mouse to select, create or edit models.
  • The Keys to Success and a Multitude of Options at Your Fingertips
    SpaceMouse Enterprise has thirty-one programmable keys, creating a richly customizable experience for every user. Eight keyboard modifiers ensure significantly less hand movement than using a standard keyboard. Five QuickView Keys with long-press function create ten views of 3D objects, while three Custom View Keys create an additional three, adding up to thirteen total views. This ensures CAD experts can double-check every angle of their work before presenting. A Rotation Toggle Key with LED signifier offers more control of objects while working, while the Fit Key brings objects back to center, keeping users from having to search for objects in their 3D space. The programmable Function Keys automatically update as users change applications or environments, with a color LCD for visualizing key assignments. The display presents actual icons from your application, offering the familiarity of a toolbar ribbon. Customizing which commands are assigned to which buttons is simple, using the simple but powerful 3DxWare 10 software. This leaves the other hand free to simultaneously use a 2D mouse for selecting, creating and editing, a system which improves both body and hand posture.
  • Ergonomics, Redefined
    SpaceMouse Enterprise is the most ergonomically designed product 3Dconnexion has ever created. It features a full-size, soft-coated hand rest for maximum comfort and a complete set of keyboard modifiers, all placed to reduce finger movement by 28.6% per hour, streamlining and simplifying workflows. In fact, this combination of features in SpaceMouse Enterprise create an environment that increases work performance by up to 28%.
  • The Foundation of the 3Dconnexion Experience
    The 3DxWare 10 software allows users to customize and optimize SpaceMouse Enterprise for peak performance. Easily assign application commands to buttons for each application or environment (such as part, assembly, drawing) and tailor other useful settings to specific needs. 3DxWare 10's clean, intuitive interface means the most useful settings are just a click away.
3Dconnexion SpaceMouse Enterprise - 3D mouse - USB
3D mouse
Wired - USB
15.4 cm x 24.9 cm x 5.8 cm
800 g
Buttons Qty
31
Programmable buttons, LCD screen
Cable Length
2 m
Apple MacOS X, Microsoft Windows
4-year warranty with product registration
3D mouse
15.4 cm
24.9 cm
5.8 cm
800 g
Input Device
Wired
USB
Buttons Qty
31
Cable Length
2 m
1 x USB - 4 pin USB Type A
BSMI, FCC, RoHS, WEEE, KC, China RoHS, RCM
Limited warranty - 4 years with product registration
Type: Mouse
Brand: 3Dconnexion
