3Dconnexion CadMouse Mouse Pad
Quicklinx: BSJBWS00 Mfr#: 3DX-700053
Hurry, only 1 left in stock!
£14.56 ex VAT
£17.47 inc VAT
The 3Dconnexion CadMouse Pad provides the ideal balance between speed and control thanks to its high-quality micro-textured coating. It enables effortless, precise mouse movement thanks to perfect equilibrium between static and kinetic friction. That means your mouse moves exactly how you mean it to - every time.
  • Perfect blend of speed and precision
  • Serious precision for serious professionals
    In professional CAD work, there is no room for anything but world-class accuracy. The clean, consistent surface texture of the 3Dconnexion CadMouse Pad enhances reflective qualities for accurate sensor readings and smooth, precise cursor movement. It's the level of professional-grade precision that engineers, architects and designers deserve.
  • Stability you can rely on
    Serious CAD professionals move their mouse hundreds of meters every day. That's why the 3Dconnexion CadMouse Pad's robust three-layer construction features a rigid top plate and silicone base that creates a stable and uniform surface you can rely on, no matter how far or fast you go.
3Dconnexion CadMouse Pad - mouse pad
Mouse pad
Product Material
Silicone, rubber
25 cm x 35 cm
160 g
Mouse pad
Product Material
Silicone, rubber
25 cm
35 cm
Thickness
0.2 cm
160 g
Non-slip
Brand: 3Dconnexion
