3Dconnexion CadMouse 8200dpi Laser Mouse
Quicklinx: B81PWS00 Mfr#: 3DX-700052
The 3Dconnexion CadMouse is designed specifically for working in CAD. Say goodbye to repetitive mouse wheel clicking and say hello to precision and comfort thanks to the advanced laser sensor and dedicated middle mouse button. Stay in control with the Smart Scroll wheel and marvel at how you ever worked without QuickZoom that effortlessly zooms to your point of interest with a single click.
  • Intelligent ergonomic design
    The days of clicking the mouse wheel are over thanks to the 3Dconnexion CadMouse's dedicated middle mouse button. It's simply more comfortable and convenient to press than the scroll wheel. The device is housed in a stylish matte ergonomic design that supports your hand in a comfortable and natural position, hour after hour.
  • Zoom the way you were meant to
    With 3Dconnexion's QuickZoom, you can effortlessly zoom in and out of your geometry with a single click of a thumb button. But don't worry, scroll wheel lovers: the Smart Scroll wheel delivers precise click-to-click zooming in CAD applications or speedy scrolling with inertia effects in browsers and documents.
  • Control your cursor with engineering precision
    With the 3Dconnexion CadMouse, you're in complete control thanks to its advanced laser sensor. With 8200 dpi and a poll rate up to 1000Hz you'll click exactly where you need to, when you need to. It's the level of precision CAD professionals demand - and deserve.
  • Effortless access to your favorite commands
    The gesture button opens an application or environment-specific radial menu so you can access your favorite commands with a simple mouse gesture.
  • Quiet as a mouse
    The acute attention was paid to how materials and geometry affect static and kinetic friction during mouse movement. The 3Dconnexion CadMouse has optimally shaped PTFE feet that create the least static friction and result in near-silent operation.
  • The perfect blend of speed and precision
    The 3Dconnexion CadMouse Pad provides the ideal balance between speed and control thanks to its high-quality micro-textured coating.
3Dconnexion CadMouse - mouse - USB - matte black, steel
Mouse
Wired - USB
Matte black, steel
Orientation
Right-handed
8 cm x 12.8 cm x 4.4 cm
130 g
Movement Detection Technology
Laser
Buttons Qty
7
Movement Resolution
8200 dpi
Performance
Polling rate: 1000 Hz
QuickZoom, Smart Scroll, radial menu button, polytetrafluoroethylene (PTFE) feet
Microsoft Windows Vista / 7 / 8
Mouse
Orientation
Right-handed
8 cm
12.8 cm
4.4 cm
130 g
Matte black, steel
Input Device
Wired
USB
Laser
Buttons Qty
7
Movement Resolution
8200 dpi
Performance
1 x USB - 4 pin USB Type A
FCC, KC, RCM, BSMI, RoHS, China RoHS, WEEE
