The CubePro features build platform with ultra high-resolution. With ultra high-resolution settings of 70-micron thin print layers, professional quality printing has never been so large or easy.
CubePro will support nylon, along with strong ABS and compostable PLA plastic for production. Create functional prototype models or make end-use parts for your engineering applications. The CubePro is a versatile printer for both the engineer and hobbyist alike. Nylon is exceptionally durable for high heat resistance, high strength to weight ratio, or parts requiring secondary operations like painting, machining or adhesive bonding.
A controlled process environment ensures improved accuracy and reliability of print for effortless, professional quality every time for your largest ABS plastic prints. Automated settings ensure home-safe printing in your mancave, on your workbench and at your desktop.
Print big, make precise
The CubePro features build platform with ultra high-resolution. With ultra high-resolution settings of 70-micron thin print layers, professional quality printing has never been so large or easy. -
Durable material - nylon
CubePro will support nylon, along with strong ABS and compostable PLA plastic for production. Create functional prototype models or make end-use parts for your engineering applications. The CubePro is a versatile printer for both the engineer and hobbyist alike. Nylon is exceptionally durable for high heat resistance, high strength to weight ratio, or parts requiring secondary operations like painting, machining or adhesive bonding. -
Controlled print environment
A controlled process environment ensures improved accuracy and reliability of print for effortless, professional quality every time for your largest ABS plastic prints. Automated settings ensure home-safe printing in your mancave, on your workbench and at your desktop. -
Strong, fast & long-lasting
Guaranteed faster, more accurate prints with stabilized print mechanics and easy feed cartridges for prolonged material life. -
Triple color + three materials = thousands of options
Get more expressive with 3D printing in up to 3 simultaneous colors with 3 material options. Select from vibrant colors for more unique combinations. -
Connect better to experience better
Connect conveniently with an easy to use color touchscreen display and Wi-Fi capability.
- 3D Systems CubePro Trio - 3D printer
- Printer Type
- 3D printer - FDM - 3 colour printing
- 38.5 kg
- Max Build Size
- 270.4 x 200.4 x 230 mm
- Build Speed
- 15 mm3/sec
- Min Layer Thickness
- 70 µm
- Interface
- USB, Wi-Fi
- Build Materials Supported
- Polylactide (PLA), acrylonitrile butadiene styrene (ABS)
- System Requirements
- Microsoft Windows 7, Microsoft Windows XP Professional SP3, Microsoft Windows XP Home Edition SP3
- 57.8 cm x 57.8 cm x 59.1 cm
- Printer Type
- 3D printer
- Technology
- Fused Deposition Modeling (FDM)
- Multicolour Print
- Yes (3 colour printing)
Printer
- Build Speed
- 15 mm3/sec
- Built-in Devices
- Status LCD, touch screen
- Connectivity Technology
- Wired
- Interface
- USB, Wi-Fi
- 70 µm
- Input File Formats Supported
- STL
Media Handling
- Max Build Size
- Connections
- 1 x USB - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- Power Device
- Power supply - internal
- OS Required
- System Requirements Details
- 2 GHz - RAM 2 GB
- 57.8 cm
- 57.8 cm
- 59.1 cm
- 38.5 kg
