3Com 4200G 24-Port Gigabit PoE Switch
Quicklinx: 62KZWS00 Mfr#: 3CR17671-91-UK
The 3Com Switch 4200G is an affordable, managed entry-level Gigabit switch, perfect for cost-conscious medium-sized businesses wanting a fast, efficient network upgrade. Layer 2 switching along with Layer 3 static routing make the Switch 4200G ideal for wiring closet and workgroup connectivity.
It delivers quad-speed performance - 10/100/1000 and 10-Gigabit Ethernet. The Switch 4200G features 20 auto-negotiating 10/100/1000 ports configured as auto-MDI/MDIX, four dual-personality 10/100/1000 or SFP Gigabit ports, and two 10-Gigabit slots. Up to 32 devices can be clustered together for easy administration. Power over Ethernet is supported on all 10/100/1000 ports.
QoS and traffic management features help ensure essential applications get the appropriate priority for efficient utilization of network resources. Furthermore, this switch has enterprise-class security features including IEEE 802.1X network login, SSH/SSL encrypted device log-in, and Access Control Lists. IEEE8023af Power over Ethernet supports convergence-ready networking, with all 24 ports at full 15.4W standard power.
3Com Switch 4200G PWR - switch - 24 ports - Managed
Switch - 24 ports - Managed - stackable
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE) + 4 x shared SFP + 2 x XENPAK
Power Over Ethernet (PoE)
PoE
MAC Address Table Size
8K entries
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH-2
Full duplex capability, Layer 2 switching, PoE, auto-negotiation, BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, ACL support
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s
44.2 cm x 43 cm x 4.4 cm
6.9 kg
United Kingdom
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
PoE
8K entries
Max Units In A Stack
16
Routing Protocol
Static IP routing
Encryption Algorithm
MD5, SSL, TLS, PEAP
Authentication Method
RADIUS, PAP, CHAP, Secure Shell v.2 (SSH2)
Status Indicators
Port status, power
1 x console management , 24 x 1000Base-T RJ-45 PoE , 4 x SFP (mini-GBIC) , 2 x XENPAK
Internal power supply
1 x serial cable
Rack Mounting Kit
Included
FCC Class A certified, CISPR 22 Class A, EN 61000-3-2, IEC 61000-3-2, IEC 61000-3-3, VCCI Class A ITE, EN 61000-3-3, EN55024, EN55022 Class A, FCC Part 15, ICES-003 Class A, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1
United Kingdom
44.2 cm
43 cm
4.4 cm
6.9 kg
Limited warranty - lifetime
10 - 95%
