2-Power Universal Camera Battery Charger
Quicklinx: BG1JWS00 Mfr#: UDC5001A-RPUK
Type: Charger
£21.44 ex VAT
£25.72 inc VAT
2-Power Universal Battery Charger
Universal Battery Charger suitable for charging many types of low voltage battery packs for Cameras, Camcorders, Mobile Phones etc. Simply adjust the charging pins manually to correspond to your batterys contacts and plug in to the mains or DC Car socket to begin charging. The charger automatically senses positive and negative polarity and is suitable for charging 3.6v, 3.7v, 7.2v & 7.4v Lithium ion Battery Packs.
The unit is also able to charge AA & AAA NiMH recharegable batteries and USB enabled devices via the 5V 1000mA USB port.
2-Power Universal Battery Charger battery charger / charging stand - + car power adapter
Battery charger / charging stand
6.8 cm x 2.9 cm x 11.8 cm
132 g
United Kingdom
Output Connector Type
USB
AC 230 V
Voltage Provided
5 V
1-year warranty
Battery charger / charging stand + car power adapter
6.8 cm
2.9 cm
11.8 cm
132 g
United Kingdom
AC 230 V
Input Connectors
Power 3-pole, power DC jack
Voltage Provided
5 V
Output connectors
4 pin USB Type A
Max Electric Current
1000 mA
Car Power Adapter Included
Supported Battery
AA, AAA
Nickel Metal Hydride, Lithium Ion
Limited warranty - 1 year
BG1J C2G 2m USB 2.0 A/B Cable - Black In Stock £3.81
BG1J C2G 5m USB 2.0 A/B Cable - Black In Stock £5.13
BG1J C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.96
BG1J C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.00
Type: Charger
Brand: 2-Power
Price Range Ex VAT: 0 - 50
