2-Power Universal Battery Charger
Universal Battery Charger suitable for charging many types of low voltage battery packs for Cameras, Camcorders, Mobile Phones etc. Simply adjust the charging pins manually to correspond to your batterys contacts and plug in to the mains or DC Car socket to begin charging. The charger automatically senses positive and negative polarity and is suitable for charging 3.6v, 3.7v, 7.2v & 7.4v Lithium ion Battery Packs.
The unit is also able to charge AA & AAA NiMH recharegable batteries and USB enabled devices via the 5V 1000mA USB port.
- 2-Power Universal Battery Charger battery charger / charging stand + car power adapter - USB
- Product Type
- Battery charger / charging stand + car power adapter
- 6.8 cm x 2.9 cm x 11.8 cm
- 132 g
- Localisation
- United Kingdom
- Output Connector Type
- USB
- Voltage Required
- AC 230 V
- Voltage Provided
- 5 V
- Max Electric Current
- 1000 mA
- Supported Battery
- AA, AAA Nickel Metal Hydride, Lithium Ion
- 1-year warranty
- Product Type
- Designed For
- Camcorder, camera, portable player, tablet, mobile phone
- 6.8 cm
- 2.9 cm
- 11.8 cm
- 132 g
- Localisation
- United Kingdom
- Voltage Required
- AC 230 V
- Input Connectors
- Power 3-pole, power DC jack
- Voltage Provided
- 5 V
- Output connectors
- 4 pin USB Type A
- 1000 mA
- Car Power Adapter Included
Supported Battery
- Form Factor
- AA, AAA
- Technology
- Nickel Metal Hydride, Lithium Ion
- Limited warranty - 1 year
