Voltage Range
The power adapter operates within an input voltage range of AC 110-240 V, making it suitable for various electrical systems. This flexibility ensures the adapter can be used in different geographical locations without compatibility issues. -
Power Output
Providing an output voltage of 19 V and a total power output of 45 watts, this adapter is designed to meet the power requirements of devices while ensuring efficient charging and performance. -
Current Capacity
With a maximum electric current of 2.37 A, this power adapter can charge devices quickly, reducing downtime and allowing users to stay productive. -
Compact Design
The external form factor of this power adapter enhances portability and ease of use. Its design allows for convenient connectivity without taking up unnecessary space.
 - 2-Power - power adapter - 45 Watt
 - Power adapter - external
 - 128 g
- Input Voltage
 - AC 110-240 V
- Output Voltage
 - 19 V
- Power Capacity
 - 45 Watt
 - 8.5 cm x 3.4 cm x 2.6 cm
 - 1-year warranty
- Designed For
 - Dynabook Toshiba Portégé Z10, Z10t-A-001, Z10t-A-002, Z10t-A-003, Z10t-A-005, Z10t-A-10, Z10t-A-102, Z10t-A-103, Z10t-A-104, Z10t-A-106, Z10t-A-11, Z10t-A-111, Z10t-A1110, Z10t-A1111, Z10T-A-112, Z10t-A-119, Z10t-A-12, Z10t-A-121, Z10t-A-122, Z10t-A-124, Z10t-A-125, Z10t-A2111, Z10t-A3261
- Input Voltage
 - AC 110-240 V
- Output Voltage
 - 19 V
- Max Electric Current
 - 2.37 A
- Power Capacity
 - 45 Watt
 - Limited warranty - 1 year
 - 8.5 cm
 - 3.4 cm
 - 2.6 cm
 - 128 g
- Designed For
 - Dynabook Toshiba Portégé Z10T, Z10t-A, Z10t-A-001, Z10t-A-002-1, Z10t-A-002-2, Z10t-A-003, Z10t-A-003-2, Z10t-A-005, Z10t-A-102, Z10t-A-103, Z10t-A-104, Z10t-A-106, Z10t-A-10H, Z10t-A-10M, Z10t-A-111, Z10t-A1110, Z10t-A1111, Z10T-A-112, Z10t-A-119, Z10t-A-11C, Z10t-A-11Q, Z10t-A-11Z, Z10t-A-121, Z10t-A-122, Z10t-A-124, Z10t-A-125, Z10t-A-12J, Z10t-A-12M, Z10t-A-12N, Z10t-A-12V, Z10t-A-12W, Z10t-A-12X, Z10t-A-12Z, Z10t-A2111, Z10t-A3261
