Efficient power supply
The power adapter is designed to provide a consistent and reliable power output, ensuring that devices operate smoothly without interruptions. -
Broad compatibility
With a voltage requirement of AC 110-240 V, this adapter can be used in various regions, making it suitable for both home and travel use. -
Compact external design
The external form factor allows for easy connection and disconnection, making it convenient to use with different devices.
- 2-Power - power adapter - 45 Watt
- Power adapter - external
- 128 g
- Input Voltage
- AC 110-240 V
- Output Voltage
- 12 V
- Power Capacity
- 45 Watt
- 8.5 cm x 3.4 cm x 2.6 cm
- 1-year warranty
- Designed For
- Microsoft Surface 2, RT
- Input Voltage
- AC 110-240 V
- Output Voltage
- 12 V
- Max Electric Current
- 3.6 A
- Power Capacity
- 45 Watt
- Limited warranty - 1 year
- 8.5 cm
- 3.4 cm
- 2.6 cm
- 128 g
- Designed For
