Versatile power compatibility
The power adapter supports a wide input voltage range of AC 110-240 V, making it adaptable for various regions and power sources. -
Reliable power output
With a steady 12 V output voltage, the adapter ensures devices receive the appropriate energy necessary for their operation. -
Efficient power delivery
Providing up to 36 watts of power, this adapter is capable of efficiently supporting multiple devices simultaneously. -
Adequate current capacity
A maximum electric current of 3 A allows for reliable use with devices that require more power, enhancing its usability. -
Compact and portable design
The external form factor of this power adapter makes it convenient to carry and use in various environments without taking up much space.
- 2-Power - power adapter - 36 Watt
- Power adapter - external
- 128 g
- Input Voltage
- AC 110-240 V
- Output Voltage
- 12 V
- Power Capacity
- 36 Watt
- 8.5 cm x 3.4 cm x 2.6 cm
- 1-year warranty
- Input Voltage
- AC 110-240 V
- Output Voltage
- 12 V
- Max Electric Current
- 3 A
- Power Capacity
- 36 Watt
- Limited warranty - 1 year
- 8.5 cm
- 3.4 cm
- 2.6 cm
- 128 g
