Reliable memory performance
With a CAS Latency of CL11 and adherence to the PC3-12800 memory specification, this memory module ensures smooth and efficient operation under various workloads. -
Easy system upgrades
The DIMM 240-pin form factor allows users to expand their memory capacity without hassle.
- 2-Power - DDR3 - module - 8 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3-12800)
- Latency Timings
- CL11
- Dual rank, unbuffered
- 1-year warranty
- Capacity
- 8 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL11
- Non-ECC
- 1-year warranty
