Many competitors claim to offer full LED BLU displays but most simply fall short of the mark. Samsung. The only real LED BLU display.
Conjuring picture perfect performance
It's not an illusion, each Samsung monitor's 2-millisecond response time makes faster, clearer images a reality. No matter how quick the action gets, this monitor keeps up with the scene, delivering stunning, seamless motion imaging that enhances your movie viewing, game playing and internet streaming experience. There's no juddering, blurring or ghosting, just smooth viewing that you can totally immerse yourself in. With Magic Speed, finally magic you can believe in. -
Mega colour, Mega contrast, Mega experience
There's dynamic and then there's Mega Dynamic. With an upgraded contrast ratio - the highest level of contrast ratio currently available - Samsung monitors deliver professional picture quality that makes colours more rich and real then you've dreamt possible. So real, you'll see each eye-popping colour and crystal-clear detail come to life right on your screen. -
Perfect Viewing Experience with Magic Lux
Magic Angle creates the perfect viewing position when you are lying down. By recreating the image purity that you see when viewing the screen from the front, Magic Angle makes entertainment more comfortable. When returning to a normal viewing position, Magic Angle should always be turned off to ensure ocular comfort. -
Control brightness, conserve energy
Magic Eco makes saving energy easy. It adjusts Samsung monitor's brightness based on how much energy you want to save. You have four energy saving options to choose from: 100%, 75%, and 50% power consumption as well as ‘power saving off'. If Magic Eco is turned off, you still enjoy the option of using Samsung's Magic Bright feature, engineered to let you manually adjust the screen's brightness. Take the effort out of saving energy and take control with Magic Eco. -
A monitor that takes the initiative to share
With Samsung's Magic Return you never have to worry about your second monitor losing content. If the cable disconnects and the signal disappears, Magic Return automatically transfers the content from that screen to the other monitor before turning off. There's no magic here. We just have content sharing down to a science.
- Samsung SyncMaster BX2450 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 2 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, VGA
- Tilt
- Coal grey
- 57.7 cm x 20.9 cm x 43.5 cm
- 4 kg
- Microsoft Certification
- Certified for Windows Vista
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Plug and Play, DDC-2B
- Display Type
- Diagonal Size
- 24"
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 2 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Power off timer, MagicTune, MagicWizard, MagicAngle, MagicReturn, MagicEco, MagicBright 3
- Coal grey
- 4 kg
- VGA , 2 x HDMI
Mechanical
- Tilt
- Cables Included
- 1 x VGA cable
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Power Supply
- Internal
- Power Consumption (Typical)
- 27 Watt
- Power Consumption Stand by / Sleep
- 0.3 Watt
- Shipping Width
- 74.5 cm
- Shipping Depth
- 42.8 cm
- Shipping Height
- 14.1 cm
- Shipping Weight
- 5.8 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
