Samsung 24" G32A FullHD Odyssey Gaming Monitor
Quicklinx: GQW4WS00 Mfr#: LS24AG320NUXXU
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: None
Interfaces: DisplayPort, HDMI
25 In Stock
£165.84 ex VAT
£199.00 inc VAT
165 Hz refresh rate and 1 ms response time makes it perfect for crisp and smooth gameplay - you'll appreciate that extra in fast-paced online titles like CS:GO or Valorant
AMD Freesync Premium technology takes care of screen tearing, blurring and other artefacts for smooth action in games, even if your framerate dips lower now and then
Full HD VA screen boasts sharp contrast, deep blacks and wide viewing angles, so it even looks great from the side
Fully adjustable stand lets you to get the viewing angle just right, so you can keep a healthy posture throughout your gaming marathons
This monitor has low blue light and is flicker free, so it goes easy on your eyes
  • At the heart of the action
    Race ahead. Thanks to its fast refresh rate, Odyssey G3 eliminates lag and blur for an exhilarating gaming experience with ultra-smooth action.
  • Gain the upper hand against your enemies
    Every moment counts. With a response time of 1 ms, screen pixels change color almost instantaneously. So screen performance is almost as fast as your reflexes.
  • Play without interruption
    Smooth, effortless gaming. AMD FreeSync Premium compatibility synchronizes the graphics card with the screen to reduce lag and image tearing.
  • Tailor your screen to your game
    Play for victory. Odyssey G3 features a height-adjustable stand and a screen that tilts, swivels and rotates up to 90° (portrait mode). Complete ergonomics for optimum gaming comfort.
  • Enjoy a wider view
    Play without limits. Ultra-thin edges give you a wider playing field. Thin edges are ideal for dual-monitor setups, so you don't miss a single enemy.
  • Protect your eyes to play longer
    Play even longer without eyestrain. Flicker Free technology eliminates flicker effects to ensure a comfortable viewing experience. In addition, blue light emissions known to damage the retina are reduced.
Samsung Odyssey G3 S24AG320NU - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class E
Energy Consumption per Year
23 kWh
Adaptive-Sync Technology
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 165 Hz
Pixel Pitch
0.2767 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
1 ms (MPRT)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Voltage
AC 100-240 V (50/60 Hz)
54.4 cm x 23.42 cm x 49.87 cm
4.5 kg
Display Type
Energy Class
Class E
23 kWh
Diagonal Size
24"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2767 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
72% NTSC
Response Time
1 ms (MPRT)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Game mode, Mega Dynamic Contrast Ratio, Black eQualizer, Flicker Free technology, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, Refresh Rate Optimizer, 3 Side Borderless Design
54.4 cm x 23.42 cm x 49.87 cm - with stand
4.5 kg
HDMI , DisplayPort 1.2 , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
30
Rotation Angle
-2/+92
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable
Security Slot Type
Kensington security slot
Input Voltage
16 kWh/1000h
Power Consumption (Typical)
16 Watt
Power Consumption (Max)
25 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 54.4 cm - depth: 23.42 cm - height: 49.87 cm - weight: 4.5 kg , Without stand - width: 54.4 cm - depth: 9.2 cm - height: 33.33 cm - weight: 3 kg
Shipping Width
63.6 cm
Shipping Depth
45.4 cm
Shipping Height
21.15 cm
Shipping Weight
6.6 kg
10 °C
10 - 80% (non-condensing)
Diagonal Size: 24in
Response Time: 1ms
Speakers: None
Interfaces: HDMI
Brand: Samsung
