Samsung 32" Odyssey G65B QHD Smart Gaming Monitor
Quicklinx: H7XNWS00 Mfr#: LS32BG650EUXXU
Diagonal Size: 32in
Max Resolution: 2560 x 1440
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
25 In Stock
£449.17 ex VAT
£539.00 inc VAT
This G65B series provides smart functionality, including the option to create a home office environment even without a PC. The monitors conveniently connect with various IT devices and services all from one screen for an ultra-efficient working environment. Users can wirelessly connect to a Windows or Mac PC, use Samsung DeX, mirror a smartphone screen onto the monitor using Apple AirPlay 2 as well as access Microsoft 365 cloud services. Users can also watch the shows on Netflix, Amazon Prime and other leading OTT (over-the-top) service providers.
The G65B is equipped with a 240 Hz refresh rate and 1 ms response time (GtG). The QHD, 1000R curved display comes with FreeSync Premium Pro for a flawless gaming experience that will give any player a competitive edge.
  • Hidden details shining bright - DisplayHDR 600
    Reveal the whole picture. DisplayHDR 600 delivers more contrast, with deeper blacks and brighter whites to help you uncover enemies or secrets lurking in the shadows. Even in dark scenes, every detail shines with clarity.
  • React in real time - 240 Hz refresh rate & 1 ms response time
    Speed through scenes. 240 Hz refresh rate eliminates lag for exhilarating gameplay with ultra-smooth action. Jump on enemies right when you see them with a 1 ms response time and blur-free frames.
  • Focus without ever breaking flow - AMD FreeSync Premium Pro
    Effortlessly smooth game play. AMD FreeSync Premium Pro features adaptive sync technology which reduces screen tearing, stutter, and input latency. Low frame rate compensation ensures every scene flows seamlessly.
  • Overwhelm your senses - 1000R Curve
    Vivid scenes wrap even more tightly around you. Experience the next level of heart-pounding gaming that's superior to anything you've seen before. The 1000R display fills your peripheral vision and draws you into the character's shoes.
  • Where gaming comes together - Samsung Gaming Hub
    The best of gaming all in one place. Samsung Gaming Hub allows instant access to top cloud gaming services, as well as your favorite console games. Smooth visuals and responsive gameplay are powered by advanced game streaming technology without downloads or storage limits - just turn on and play.
  • Quick, simple setup to seize the win - game bar
    Check and control game settings in an instant. Now, you can easily view the status of the most important settings such as FPS or HDR. Modify response time, screen ratio, and game picture mode on any game screen for uninterrupted focus.
  • Convenience in mind - Ergonomic stand
    Reach the height of success. Swivel, tilt, and adjust the monitor position until you're set up for victory. Fully compatible with VESA-standard monitor arms, the screen can be moved effortlessly to your ideal staging.
  • Your favorite shows in one space - Smart TV experience
    Take a break from marathon gaming sessions and catch up on must-see streaming content in sharp quad high definition, with just a simple Wi-Fi connection. Samsung TV Plus offers free live content with no downloads or sign-ups as well as personalized content recommendations from Universal Guide.
  • Unseen sides revealed - ultrawide game view
    Find more with an extended view. Discover hidden gems or flank enemies in full stealth with the ultrawide 21:9 aspect ratio. Extra context in every match brings you closer to the top of the leaderboard.
  • Designed to light up your world - CoreSync & Core lighting design
    With core lighting, add personality to your setup with multiple color modes that leap off the screen and into your reality. Gaming escapes beyond the screen with ambient CoreSync technology that matches your game's on-screen colors for world-blending immersion.
  • Instant auto connect - Auto Source Switch+
    Power on for instant action. With Auto Source Switch+, your monitor detects when connected devices are turned on and instantly switches to the new source signal. This helps you get to your game play faster without flipping through multiple input sources.
Samsung Odyssey G6 S32BG650EU - G65B Series - LED monitor - curved - QHD - 32" - HDR
LED-backlit LCD monitor - 32" - Smart monitor
Energy Class
Class F
Energy Consumption per Year
44 kWh
Curved Screen
Adaptive-Sync Technology
Wi-Fi, USB 3.0 hub, Bluetooth 5.2 adapter
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 240 Hz
Brightness
350 cd/m²
Contrast Ratio
2500:1
HDR Capable
DisplayHDR 600
Response Time
1 ms (grey-to-grey)
Gaming
Colour Support
1 billion colours
Colour Gamut
95% DCI-P3
Input Connectors
2xHDMI, DisplayPort
Built-in Ethernet
Display Position Adjustments
Voltage
AC 100-240 V
71.3 cm x 31.11 cm x 60.62 cm
7.4 kg
CEC, HDCP 2.2
Display Type
LED-backlit LCD monitor / TFT active matrix - Smart monitor
Energy Class
Class F
Energy Class (HDR)
Class G
44 kWh
Diagonal Size
32"
Curved Screen
Yes (1000R)
Operating System
Tizen
Built-in Devices
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
2500:1
HDR Certification
DisplayHDR 600
Colour Support
1 billion colours
Colour Gamut
95% DCI-P3
Response Time
1 ms (grey-to-grey)
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Game mode, ConnectShare, Flicker Free technology, Image Size, Eye Saver Mode, Factory Tunning, Factory Calibration Report, Movie Mode, DLNA, Quantum Dot Technology, Graphics Mode, Auto Source Switch+, Adaptive Picture, Ultrawide Game View, Tap View, Sound Mirroring, CoreSync lighting design, Adaptive Sound, Game Bar 2.0, far-field voice interaction, Virtual AIM Point, Mobile to Screen Mirroring, Gaming Hub, Workspace, Samsung TV Plus, Colour Mode, Entertain Mode
71.3 cm x 31.11 cm x 60.62 cm - with stand
7.4 kg
Audio
Speakers
2 x HDMI (HDCP 2.2) , DisplayPort 1.4 , Headphones , 2 x USB 3.0 , LAN (RJ-45)
Mechanical
Tilt Angle
-9/+13
Swivel Angle
30
Rotation Angle
-92/+92
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Remote control
1 x DisplayPort cable
CEC, HDCP 2.2
Security Slot Type
Kensington security slot
Input Voltage
AC 100-240 V
30 kWh/1000h
Power Consumption HDR (On mode)
83 kWh/1000h
Power Consumption (Typical)
30 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Intel Wireless Display, Microsoft 365, SmartThings, Google Duo, Bixby Voice Assistant
Dimensions & Weight Details
With stand - width: 71.3 cm - depth: 31.11 cm - height: 60.62 cm - weight: 7.4 kg , Without stand - width: 71.3 cm - depth: 18.15 cm - height: 43.97 cm - weight: 5.5 kg
Shipping Width
82.7 cm
Shipping Depth
49.4 cm
Shipping Height
22.6 cm
Shipping Weight
10.1 kg
10 °C
10 - 80% (non-condensing)
Diagonal Size: 32in
Response Time: 1ms
Interfaces: HDMI
Brand: Samsung
