Samsung 32" M80C, USB-C, UHD Warm White Smart Monitor
Quicklinx: HBC1WS00 Mfr#: LS32CM801UUXXU
Diagonal Size: 32in
Max Resolution: 3840 x 2160
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: USB-C, HDMI
14 In Stock
£566.66 ex VAT
£679.99 inc VAT
The M80C smart monitors from Samsung enable users to tailor their monitors to their unique styles and needs, as they watch, play and work.
  • Elegant designs for every style and space
    With an iconic slim design, the M8 models are super slim, measuring 11.39 mm at the thinnest point on the monitor. To elevate the look of the monitor and the room surrounding it, an organic, chic herringbone pattern has been applied to the back of the M8 models. The height-adjustable stand with tilt support helps M8 users adjust the angle whenever they need to, while creating a clutter-free environment. The screen can also pivot 90 degrees to reduce the fatigue of scrolling down long files.
  • Monitors that redefine smart entertainment
    The 2023 Smart Monitor M8 has received multiple upgrades and feature enhancements from the previous generation. Thanks to 4K resolution, HDR 10+ and 400 nit brightness, the M8 delivers brilliant, vivid pictures to offer the best of smart entertainment in a monitor. M8 users can enjoy easy access to Samsung Gaming Hub, the all-in-one streaming platform, as well as Smart Hub for services such as Prime Video, Netflix and YouTube. The M8 also supports color coverage up to 99% sRGB color gamut to bring all content to life in brilliant color for designers and creators.
  • Upgraded monitors for maximum productivity
    The 2023 lineup has been enhanced to make remote work seamless and effortless. The PC-less workspace allows remote access by wirelessly connecting to and mirroring PCs. The M8 has a magnetic and removable camera so users can connect wirelessly with no additional purchase necessary. Its SlimFit camera supports FHD resolution and video conferencing features. Users can now connect to Google Meet and other apps while leveraging Auto Framing capabilities for more effective meetings.
  • Next-level monitors with personalized features
    Users can easily control all their in-home IoT devices from a single monitor thanks to the built-in IoT Hub, supporting Zigbee and Thread. The M8 include built-in voice assistants, including Bixby and Amazon Alexa, enabling users to control the monitor with their voice. Far-field voice is also supported in the M8 and M7 models with a built-in mic, allowing users to speak directly to the monitor.
Samsung S32CM801UU - M80C Series - LED monitor - 4K - 32" - HDR
LED-backlit LCD monitor - 32" - Smart monitor
Energy Class
Class G
Energy Consumption per Year
48 kWh
Remote control, Wi-Fi, USB 2.0/USB-C hub, Bluetooth 5.2 adapter, USB PD 65 Watt
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1845 mm
Brightness
400 cd/m²
Contrast Ratio
3000:1
HDR Capable
HDR10+
Response Time
4 ms (grey-to-grey)
Colour Support
1 billion colours
Colour Gamut
99% sRGB (CIE 1931)
Input Connectors
HDMI, USB-C
Display Position Adjustments
Height, pivot (rotation), tilt
Voltage
AC 100-240 V
Warm white
71.34 cm x 20.01 cm x 61.62 cm
7.2 kg
CEC, ISO 9241-307 Class 2
Display Type
LED-backlit LCD monitor / TFT active matrix - Smart monitor
Energy Class
Class G
Energy Class (HDR)
Class G
48 kWh
Diagonal Size
32"
Operating System
Tizen
Built-in Devices
USB Power Delivery
65 Watt
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1845 mm
Brightness
400 cd/m²
Contrast Ratio
3000:1
HDR Format
HDR10+
Colour Support
1 billion colours
Colour Gamut
99% sRGB (CIE 1931)
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Multilingual
MultiView, game mode, Smart TV, Flicker Free technology, Image Size, Eye Saver Mode, Auto Source Switch+, Adaptive Picture, Tap View, Remote Access, Sound Mirroring, Adaptive Sound+, far-field voice interaction, Virtual AIM Point, Wireless DeX, IoT Hub, Gaming Hub, SmartThings, Workspace, Samsung TV Plus, Nifty Gateway, Samsung Knox Vault
Warm white
71.34 cm x 20.01 cm x 61.62 cm - with stand
7.2 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
Input
Remote control
HDMI (HDCP 2.2) , USB-C (HDCP 2.2 / power up to 65W) , 2 x USB 2.0
Mechanical
Tilt Angle
-2/+15
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), screen mirroring, Samsung DeX, Bixby Voice Assistant, AirPlay 2, Amazon Alexa Voice Assistant
SlimFit Camera
1 x HDMI cable , 1 x USB-C cable
Security Slot Type
Kensington security slot
Input Voltage
AC 100-240 V
33 kWh/1000h
Power Consumption HDR (On mode)
37 kWh/1000h
Power Consumption (Typical)
33.2 Watt
Power Consumption (Max)
140 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Intel Wireless Display, Microsoft 365, Google Meet
Dimensions & Weight Details
With stand - width: 71.34 cm - depth: 20.01 cm - height: 61.62 cm - weight: 7.2 kg , Without stand - width: 71.34 cm - depth: 2.45 cm - height: 42.38 cm - weight: 4.2 kg
Shipping Width
92.5 cm
Shipping Depth
13.2 cm
Shipping Height
48.5 cm
Shipping Weight
10.2 kg
10 °C
10 - 80% (non-condensing)
Diagonal Size: 32in
Response Time: 4ms
Interfaces: USB-C
Interfaces: HDMI
Brand: Samsung
Price Range Ex VAT: £500 - £750
