Samsung S22D300NY 21.5" 1920x1080 5ms VGA HD LED Black Monitor
AMAZING LOW PRICE!
Quicklinx: 9HLLWS00 Mfr#: LS22D300NY/XU
Experience amazing new levels of color, brilliance and picture quality through the very latest in Mega Dynamic Contrast Ratio. Samsung SA300 monitors deliver images so real-to-life that it will transform your whole viewing experience. Packed with breathtaking 5,000,000:1 contrast ratio, the highest level currently available, the SA300 monitor ensures that blacks are at their absolute darkest and (with pristine whites) colors are at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity. It is like an explosion of colors and leaves other screens seeming dull in comparison. So, take your viewing pleasure to the next level with Samsung Mega Dynamic Contrast Ratio - and enjoy your multimedia content with the professionalism it deserves.
  • Style and functionality in one design
    With its high-gloss black finish, transparent red gradation around the screen, and clean lines, this monitor has a sophisticated and modern design that is sure to make an impression.
  • Upscale your view with better quality
    Magic Upscale Technology enhances the image quality no matter what the original picture quality was. Magic Upscale prevents image degradation when scaling up and gives only the most brilliant and pristine colors and images.
  • Experience real color with mega DCR
    Mega Dynamic Contrast Ratio delivers enhanced levels of color and picture quality to your viewing experience with images that are real-to-life. Mega DCR's contrast ratio shows blacks at their absolute darkest and whites and colors at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity.
  • Less power consumption, conserve energy
    Eco Saving makes saving energy easy. The brightness of the monitor can be adjusted based on how much energy you want to save. And with the choice of three energy saving modes and Power Saving off, you can tailor your monitor use to meet your own personal needs.
Samsung S22D300NY - SD300 Series - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
600:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Voltage
Black lacquer
51.16 cm x 17.7 cm x 38.52 cm
2.85 kg
Display Type
Diagonal Size
21.5"
Panel Type
TN
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
600:1
Colour Support
Response Time
5 ms
Backlight Technology
LED backlight
Power off timer, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale
Black lacquer
51.16 cm x 17.7 cm x 38.52 cm - with stand
2.85 kg
VGA
1 x VGA cable
Power Supply
External
Input Voltage
Power Consumption (Typical)
22 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 51.16 cm - depth: 17.7 cm - height: 38.52 cm - weight: 2.85 kg , Without stand - width: 51.16 cm - depth: 5.31 cm - height: 31.08 cm - weight: 2.6 kg
