Samsung 27" G32A FullHD Odyssey Gaming Monitor
Quicklinx: GQW5WS00 Mfr#: LS27AG320NUXXU
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: None
Interfaces: DisplayPort, HDMI
£207.50 ex VAT
£249.00 inc VAT
165Hz refresh rate Conquer every enemy, even at soaring speeds. 165Hz refresh rate eliminates lag and motion blur for exhilarating gameplay with ultra-smooth action.
1ms response time (MPRT) Make every move count with a 1ms response time. Screen pixels change colours with near instant response, enabling fast-paced action to flow with real-world accuracy.
AMD FreeSync Premium Effortlessly smooth gameplay. AMD FreeSync Premium features adaptive sync technology which reduces screen tearing, stutter, and input latency.
Ergonomic design Reach the height of winning. Swivel, tilt, and adjust your monitor until all enemies are in perfect view. Your display can be moved freely so you can find total gaming comfort.
3-sided Borderless design Your legacy has no boundaries. The 3-sided borderless design unveils maximum space for bigger, bolder gameplay. Line up two displays precisely in a dual-monitor setup, so no enemies slip through the crack.
  • 165Hz refresh rate: react in real time
    Conquer every enemy, even at soaring speeds. The 165Hz refresh rate eliminates lag and motion blur for exhilarating gameplay with ultra-smooth action.
  • 1ms response time (MPRT): measure reactions in milliseconds
    Make every move count with a 1ms response time. Screen pixels change color with near-instant response, enabling fast-paced action to flow with real-world accuracy. Your on-screen performance is as swift as your own reflexes.
  • AMD FreeSync Premium: uninterrupted game flow
    Effortlessly smooth gameplay. AMD FreeSync Premium features adaptive sync technology which reduces screen tearing, stutter, and input latency. Low framerate compensation ensures every scene flows seamlessly.
  • Ergonomic design: see your game your way
    Reach the height of winning. Swivel, tilt and adjust your monitor until all enemies are in perfect view. Your display can be moved freely so you can find total gaming comfort.
  • Three-sided borderless design: take in the full view
    Your legacy has no boundaries. The three-sided borderless design unveils maximum space for bigger, bolder gameplay. Line up two displays precisely in a dual-monitor setup, so no enemies slip through the cracks.
  • Eye Saver Mode and Flicker Free: fresh eyes win more
    Play for even longer. Eye Saver Mode minimizes blue light enough to keep eyes relaxed and comfortable when gaming for extended periods. Flicker Free technology continuously removes tiring and irritating screen flicker so you can focus longer with less distraction or eye strain.
Samsung Odyssey G3 S27AG320NU - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class E
Energy Consumption per Year
28 kWh
Adaptive-Sync Technology
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 165 Hz
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
1 ms (MPRT)
Gaming
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Voltage
AC 100-240 V (50/60 Hz)
61.82 cm x 23.42 cm x 52.06 cm
4.8 kg
Display Type
Energy Class
Class E
28 kWh
Diagonal Size
27"
Viewable Size
27"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
72% NTSC
Response Time
1 ms (MPRT)
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Game mode, Mega Dynamic Contrast Ratio, Black eQualizer, Flicker Free technology, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, Refresh Rate Optimizer, 3 Side Borderless Design
61.82 cm x 23.42 cm x 52.06 cm - with stand
4.8 kg
HDMI , DisplayPort 1.2 , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
30
Rotation Angle
-2/+92
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable
Security Slot Type
Kensington security slot
Input Voltage
19 kWh/1000h
Power Consumption (Typical)
19 Watt
Power Consumption (Max)
35 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.82 cm - depth: 23.42 cm - height: 52.06 cm - weight: 4.8 kg , Without stand - width: 61.82 cm - depth: 9.24 cm - height: 37.69 cm - weight: 3.3 kg
Shipping Width
70.4 cm
Shipping Depth
46.4 cm
Shipping Height
21.8 cm
Shipping Weight
7.2 kg
10 °C
10 - 80% (non-condensing)
Diagonal Size: 27in
Response Time: 1ms
Speakers: None
Interfaces: HDMI
Brand: Samsung
