Boasting a practical design with a stunning narrow bezel this monitor is perfect for educational purposes and public facilities. The Samsung SC200 really does cover all the basics, while still providing an outstanding performance, and is definitely a monitor worth investing in.
Samsung magic angle
With 5-mode angle management, enjoy a full visual experience with amazing picture clarity from whatever angle or position you view your Samsung monitor from. -
Keep your work space as efficient as your monitor
If you need a work monitor that uses office space efficiently, then Samsung LED business monitor SC200 is the perfect choice. From physically moving the monitor with the carrying handle to quickly installing, the SC200 is ready to deliver an efficient and clean work space. Optimizing your office space is now easily achieved with the Samsung LED Business Monitor SC200. -
Help business with cost-cutting technology
Minimize your work costs with the help of the DPMS 0.1 W feature. It ensures that your Samsung Business monitor SC200 only consumes a maximum of 0.1 W while in standby mode. This amazingly low consumption is beneficial both financially and environmentally, and is simply unmatched by competitors.
- Samsung S19C200BW - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- 1440 x 900
- Pixel Pitch
- 0.2835 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Matte black
- 43.94 cm x 17 cm x 37.36 cm
- 3.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV, VCCI, C-Tick, GOST, NOM, PCBC, SASO, SIQ, CCC, PSB, FCC, IRAM, UL 60950-1, EN 60950-1, KCC, CSA C22.2 No. 60950-1, KC
- 3-year warranty
- Display Type
- Diagonal Size
- 19"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- 1440 x 900
- Pixel Pitch
- 0.2835 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Power off timer, MagicTune, MagicAngle, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving
- Matte black
- 43.94 cm x 17 cm x 37.36 cm - with stand
- 3.4 kg
- DVI , VGA
Mechanical
- Tilt
- Tilt Angle
- -1/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 19 Watt
- Power Consumption Stand by
- 0.1 Watt
- Included Software
- Drivers & Utilities, Samsung MultiScreen
- Dimensions & Weight Details
- With stand - width: 43.94 cm - depth: 17 cm - height: 37.36 cm - weight: 3.4 kg , Without stand - width: 43.94 cm - depth: 7.62 cm - height: 28.99 cm - weight: 2.85 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 10 °C
- 40 °C
- 10 - 80%
