Zyxel VMG1312-B10A Wireless N VDSL2 4-port Gateway with USB
Quicklinx: C1JKWS00 Mfr#: VMG1312-B10A-GB02V1F
The ZyXEL VMG1312-B Wireless N Fibre Router provides VDSL2 of up to profile 17a with data rates of up to 100 Mbps in downstream direction and 45 Mbps upstream. The built-in VDSL2 technology supports the widespread deployment base of triple-play services such as voice, video, data, high-definition television (HDTV) and interactive gaming; it also enables operators and carriers to gradually, flexibly and cost efficiently upgrade the existing xDSL-infrastructure.
  • VDSL2 high-speed Internet access
    The VMG1312-B10A provides VDSL2 of up to profile 17A with data rates of up to 100 Mbps in downstream direction and 45 Mbps upstream. The VDSL2 technology supports the widespread deployment base of triple-play services such as voice, video, data, high-definition television (HDTV) and interactive gaming; it also enables operators and carriers to gradually, flexibly and cost efficiently upgrade the existing xDSL-infrastructure.
  • 802.11n wireless access
    With the 802.11n technology built-in, the VMG1312-B10A provides the ultimate solution for speed and coverage. With data rates of up to 300 Mbps, it provides stable, reliable wireless connections for high-speed data and multimedia delivery. It eliminates dead zones and extends coverage by employing the latest IEEE 802.11n technology, and it is backward compatible with any IEEE 802.11 b/g/n-certified device.
  • TR-069 remote management support
    With compliance to the TR-069 standard management specifications, service providers are able to manage and configure client devices remotely without manual intervention from end-users. This unique feature not only offers users with true "Plug-and-Play" experience, but also reduces the complexity of deployment and therefore saves operating and maintenance costs for service providers.
Zyxel VMG1312-B10A - wireless router - DSL modem - 802.11b/g/n - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, VDSL, ADSL2, ADSL2+, READSL, VDSL2
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Maximum number of configured SSIDs: 4
Network / Transport Protocol
PPPoE, PPPoA, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
Remote Management Protocol
Telnet, TFTP, SSH, CLI, TR-069, TR-098, TR-111
Firewall protection, Stateful Packet Inspection (SPI), DoS attack prevention, print server, parental control, firmware upgradable, file sharing, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, Multiple SSID support, hidden SSID, reset button, 3G USB Dongle Support, DHCP relay, DHCP client, Seamless Rate Adaptation (SRA), scheduler
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
18.6 cm x 12.1 cm x 3.9 cm
245 g
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
PPPoE, PPPoA, DDNS
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Authentication Method
Secure Shell (SSH), PAP, CHAP, Radio Service Set ID (SSID), MS-CHAP, MS-CHAP v.2
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, EN55022 Class B, IEC 60950-1, EN 60950-1, EN61000-3-2, EN61000-3-3
Status Indicators
Power, WLAN, LAN, USB, WPS, Internet, DSL
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.3 Annex A, ITU G.993.1, ITU G.993.2, ITU G.992.5 Annex A
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
2
Gain Level
2 dBi
External power adapter
United Kingdom
18.6 cm
12.1 cm
3.9 cm
245 g
20 - 95% (non-condensing)
