Zyxel NR7101 Outdoor WiFi 6 NR 5G Router
The Zyxel NR7101 Outdoor WiFi 6 5G NR Router supports the latest 5G NR technology whilst at the same time retaining full compatibility with 4G/3G networks.
Lightning-fast internet connectivity
The Zyxel NR7101 has DL speeds higher than 5 Gbps and 4G LTE DL speeds of up to 2 Gbps. The wide spectrum bandwidth accelerates internet speeds and reduces network latency for premium and time-sensitive connectivity services.
Fixed Wireless Access (FWA)
Deploying the NR7101 as part of FWA allows you to extend your 5G service coverage into subscribers’ homes and workplaces without extra wire infrastructure. This secures the TCOs and increases business revenue by supporting a larger number of subscribers with a premium fixed-grade connection.
Easy installation and SA/NSA dual-mode compliant
The Zyxel NR7101 is equipped with a flexible wall or pole mounting kit, integrated IEEE 802.3at Power over Ethernet (PoE) support and dedicated WiFi AP with mobile apps content graphics for eNB/gNB alignment. The NR7101 is also interoperable with both Standalone (SA) and Non-Standalone (NSA) deployments.
Remote management and upgrade
Through the LTE radio interface, the NR7101 supports TR-069, remote GUI and FTP to be fully configurable. Firmware Over-The-Air (FOTA) support enables remote firmware upgrades and troubleshooting, through events triggered by the operators.
Environmental durability
With IP68-compliant K.21 6 KV/300 A lightning protection, the Zyxel NR7101 guarantees high-quality connections, a longer device life despite the weather and natural challenges. The NR7101 can operate within a wide range of temperature and humidity, which supports your service deployed in wide territorial scopes.
Extremely fast
Speed is everything in business. Technology progresses at record pace, so companies must do whatever it takes to stay relevant. NR7101 has up to 5 Gbps data rates, which can provide your business an advantage by being faster than others. Take part in it know! -
Be the pioneer
Feeling the need to increase bandwidth and network speed at office? Want to help manufacturing production operations become more flexible and efficient with better precision and lower costs than human inspection? Get a head start on smart office or industry 5.0, it's time to upgrade to 5G and empower your future. NR7101 is poised to be your backbone of your network to pave the way for your future business success. -
Better signal, work wonders
Six 10 dBi long range directional antennas are built into the NR7101 to provide a focused networking coverage. Experience better, stronger signal strength and enhanced signal quality of 5G network for faster speed. Grab the NR7101, it's efficient and can work wonders! -
Strong backbone, stronger connection
NR7101 has industrial-grade components with outdoor-friendly design making it possible to work in harsh environment conditions where desirable signal strength is difficult to achieve or having weather challenges including strong winds and rainstorms. NR7101 guarantees high-quality connections and a longer device life, which supports your business deployment in wide territorial scopes. -
Network slicing, tailor your network
NR7101 is interoperable with both Standalone (SA) and Non-Standalone (NSA) deployments. Under SA mode, NR7101 can support network slicing function with tailored network capabilities that are essential to fulfill different business needs, like dealing complex environments with massed wired and wireless networks for separate factory and office connections, and handling of multiple-node Wi-Fi infrastructure, which can be unstable. Customize network via NR7101 to keep ahead of industry and to ensure success! -
Efficient and precise installation
A remote and simple DIY for own installation costs less than fiber as no electrician is required! To find the best signal spot for installation, you just need to use a smartphone or tablet to connect to NR7101's Wi-Fi network and follow its configuration instruction on the "Zyxel LTE Ally" app.
- Zyxel NR7101 - wireless router - WWAN - 3G, 4G, 5G - pole-mountable
- Wireless router - wireless cellular modem
- Enclosure Type
- Pole-mountable
- Generation
- 3G, 4G, 5G
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, LTE
- Wireless router
- Enclosure Type
- Pole-mountable
- Connectivity Technology
- Wireless, wired
Communications
- Wireless cellular modem
- Generation
- 3G, 4G, 5G
Aerial
- Aerial
- Internal
- Power Device
- Power injector
- Shipping Depth
- 42 cm
- -40 °C
