SCR 50AXE is an entry-level router firewall, designed for SOHO/small business, integrated with best-in-class security, and easy management with the Nebula cloud.
Threat management
Tackle against ransomware, block intrusion/exploit/dark web/ads/VPN proxy and stopping mail fraud and phishing. -
Traffic management
Traffic management helps you see how endpoint devices behave on your network; identifying applications that are traversing your network and usage of these applications. -
Country restriction
Identifies the country of origin of incoming traffic by examining its IP address. If the country is one you've chosen to filter, the SCR 50AXE denies access-protecting your network. -
Easy to use app for everyone
With a few simple clicks, your devices will be up and running in minutes. Nebula mobile app easily gets your SCR 50AXE's Wi-Fi and security features running without requiring you to have any networking knowledge. -
Fast and efficient with optimized Wi-Fi 6E
The SCR 50AXE's tri-band Wi-Fi operates concurrently to boost wireless network speed of up to 5.4 Gbps. Thanks to the 6GHz band with super-wide 160 MHz or 80MHz split channels, delivering maximum speed to multiple connections simultaneously with low latency. -
At home, in the office, it's all just connected
Nebula Cloud Networking solution allows you to just connect, protect, and manage the SCR 50AXE and other Zyxel's compatible appliances with the centralized cloud platform, Zyxel Nebula. -
Guest access, made easy
With Guest Wi-Fi, you can create a separate network for your guests to use, keeping your main network private and secure. No more sharing your personal WiFi password with strangers or worrying about them accessing sensitive information on your network. This can be set up in a few simple steps and protects your business network from outside access. -
Simple WFH VPN setup
Build secure tunnels for Work-from-home users to extend the working experience easily and securely. The SCR 50AXE's Site-to-site VPN keeps your home office securely connected without any complex VPN configuration steps. -
See more, protect more
Informative security dashboard presents status quo of the security level and analytics of threat events.
- Zyxel SCR 50AXE - wireless router - Wi-Fi 6E - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6E)
- Frequency Band
- 2.4 GHz / 5 GHz / 6 GHz
- Data Transfer Rate
- 5400 Mbps
- Performance
- Maximum data rate (2.4 GHz): 575 Mbps , Maximum data rate (5 GHz): 2400 Mbps , Maximum data rate (6 GHz): 2400 Mbps , Firewall throughput: 900 Mbps , Threat management throughput: 900 Mbps
- Capacity
- Recommended users: up to 5 , Maximum number of configured SSIDs: 4
- IPSec, PPPoE, DHCP, DDNS
- Routing Protocol
- IGMP, static IP routing
- NAT support, auto-uplink (auto MDI/MDI-X), MAC address filtering, firmware upgradable, ACS, anti-malware protection, DHCP server, port forwarding, reset button, e-mail protection, DHCP relay, IP-MAC binding, DHCP client, cloud backup, IGMP proxy, cloud managed, MU-MIMO technology, domain filter, wireless intrusion protection, Guest VLAN, Explicit Beamforming, WPS button, ransomware protection, Dark Web blocker, ads block, VPN proxy block, GeoIP
- 6.82 cm x 17.8 cm x 24.22 cm
- 651 g
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 5400 Mbps
- Performance
- Capacity
- Routing Protocol
- Encryption Algorithm
- WPA2-PSK, WPA3-PSK
- Authentication Method
- Radio Service Set ID (SSID)
- Wi-Fi Rating
- AXE5400
- BSMI, FCC
- Processor
- 1 GHz
- RAM
- 1 GB
- Flash Memory
- 256 MB
- Status Indicators
- Status
- WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- Internal
- Antenna Qty
- 4
- Power Device
- External power adapter
- 21 Watt
- Included Accessories
- Stand
- Cables Included
- 1 x network cable
- 6.82 cm
- 17.8 cm
- 24.22 cm
- 651 g
- Shipping Width
- 6.1 cm
- Shipping Depth
- 24.6 cm
- Shipping Height
- 30.35 cm
- Shipping Weight
- 1.048 kg
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
