NETGEAR WiFi Booster for Mobile amplifies WiFi coverage for mobile devices in the home by extending and strengthening an existing WiFi signal, giving you the ability to enjoy an improved wireless experience on iPads and Android tablets, smartphones, netbooks and e-readers.
DYNAMIC LED INDICATORS
Finds best location for optimal WiFi coverage and displays real-time, end-to-end network status.
wn1000rp Dynamic LEDs
Connection status between router/gateway and Extender
On/off status of Extender
Connection status between Extender and PC
PUSH 'N' CONNECT USING WPS - A secured connection at the push of a button STEP 1
Push the 'N' Connect button on the router
STEP 2
Push 'N' Connect button on your extender
STEP 3
Secure wireless connection
Boost WiFi -- Amplify your network by boosting the WiFi signal around the house and even outside on the patio Ideal for Mobile -- Extend your WiFi network for mobile devices like iPads®, iPods®, Android® tablets, e-readers, smartphones, and netbooks Reduce mobile data charges -- Reduce 3G/4G mobile data usage by connecting to WiFi while at home Enhance Existing Equipment -- Keep your current equipment and improve coverage to eliminate WiFi "dead zones" Easy Install - Simple install for all devices using a browser, no CD needed Push 'N' Connect -- Push `N' Connect using Wi-Fi Protected Setup® (WPS) allows for a quick and secure connection Optimal Coverage -- Real-time LEDs locate the best placement spot to provide optimal WiFi coverage Universal Compatibility -- Extends b/g/n WiFi signals from any existing WiFi router or service provider gateway like Belkin®, Linksys®, D-Link®, AT&T™, 2Wire®, Verizon, EarthLink®, NETGEAR® and others‡ Superior Security -- Works with all security standards including WPA-PSK, WPA2-PSK, mixed mode and WEP NETGEAR Green features -- Power on/off button, 80% recycled packaging
Boost Wi-Fi
Amplify your network by boosting the Wi-Fi signal around the house and even outside on the patio. -
Ideal for mobile
Extend your Wi-Fi network for mobile devices like iPads, iPods, Android tablets, e-Readers, smartphones, and netbooks. -
Reduce 3G/4G mobile data usage by connecting to Wi-Fi while at home. -
Enhance existing equipment
Keep your current equipment and improve coverage to eliminate Wi-Fi "dead zones". -
Easy install
It offers simple install for all devices using a browser, no CD needed. -
Push 'N' connect
Push 'N' connects using Wi-Fi Protected Setup (WPS) allows for a quick and secure connection. -
Optimal coverage
Real-time LEDs locate the best placement spot to provide optimal Wi-Fi coverage. -
Universal compatibility
It extends b/g/n Wi-Fi signals from any existing Wi-Fi router or service provider gateway like Belkin, Linksys, D-Link, AT and T, 2Wire, Verizon, EarthLink, NETGEAR and others. -
Superior security
It can works with all security standards including WPA-PSK, WPA2-PSK, mixed mode and WEP. -
NETGEAR green features
Power on/off button, 80% recycled packaging.
- NETGEAR WN1000RP WiFi Booster for Mobile - Wi-Fi range extender - Wi-Fi
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- 6.7 cm x 5.5 cm x 3.4 cm
- 100 g
- 1-year warranty
- 6.7 cm
- 5.5 cm
- 3.4 cm
- 100 g
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Frequency Band
- 2.4 GHz
- Status Indicators
- Power, status
- Wi-Fi Protected Setup (WPS), Push ‘N’ Connect button
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP
- Power Device
- External power adapter
- Limited warranty - 1 year
