NETGEAR Tri-band WiFi Mesh EX7700 Extender
Quicklinx: GCZ7WS00 Mfr#: EX7700-100UKS
Type: [N/A]
Connectivity: Wireless
Speed: 2.2Gbps
Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, Gigabit Ethernet + 4 more
Compatibility: [N/A]
  • IEEE 802.11n
21 In Stock
£111.24 ex VAT
£133.48 inc VAT
Nighthawk X6 Tri-band Wi-Fi Mesh Extender creates powerful whole home Wi-Fi using your existing Wi-Fi. EX7700 is one of the most advanced tri-band Wi-Fi mesh extenders that includes a dedicated 866 Mbps 5 GHz band for extending Internet speeds to your devices. FastLane3 Technology with dedicated Wi-Fi Link avoids cutting the extended Wi-Fi bandwidth in half. Smart Roaming intelligently connects your mobile devices to the optimal Wi-Fi for superior streaming as you move around your house. Use the same Wi-Fi name and password for seamless connectivity as you roam around the house.
  • Seamless coverage for your mobile devices
    Smart Roaming intelligently connects your mobile devices to the optimal Wi-Fi for 4K streaming, surfing and more. Now you can enjoy uninterrupted streaming on YouTube or Netflix, even as you move around the house.
  • Ultimate speed and range without bandwidth drop
    Tri-band Wi-Fi Range Extender has FastLane3 technology which features Tri-Band Wi-Fi with speeds up to 2.2 Gbps, a Dedicated Wi-Fi Link to the router to avoid halving of bandwidth of extended Wi-Fi signals and innovative antenna design for ultimate coverage. Now you get a congestion free path for all your devices to connect to the internet.
  • Connect more
    Connect your Smart TVs and game consoles to the one of the two Gigabit Ethernet ports. Intelligent LED indicators help in optimal placement of the extender.
  • 2.2 Gbps wireless access point for your Ethernet
    Do you have a pre-wired home? Easily create a tri-band access point using a wired Ethernet connexion. Pair with your existing ISP modem to enhance Wi-Fi for your small office or home office and expand your network.
  • Nighthawk Router + Nighthawk Mesh Extender
    Enjoy all the advanced router features that a Nighthawk has to offer and easily build your own powerful Wi-Fi network by adding the Tri-band Wi-Fi Range Extender. Now you have the flexibility to customise networks in 2.4 and 5 GHz. Use your existing router's SSID to create a single network or use multiple SSIDs to create separate networks.
NETGEAR Nighthawk X6 EX7700 - Wi-Fi range extender - Wi-Fi 5, Wi-Fi 5
External
Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands)
19.9 cm x 15.4 cm x 5.44 cm
530 g
1-year warranty
19.9 cm
15.4 cm
5.44 cm
530 g
External
Ports Qty
2
Wireless
Data Transfer Rate
2.2 Gbps
Line Coding Format
256 QAM
Frequency Band
Wi-Fi Rating
AC2200
Auto-sensing per device, Wi-Fi Protected Setup (WPS), reset button, on/off switches, Tri-Band, Smart Connect, FastLane3 technology
Encryption Algorithm
WPA, WPA2-PSK, WEP
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac
2 x 1000Base-T - RJ-45
External power adapter
Limited warranty - 1 year , Technical support - 90 days
Type: [N/A]
Speed: 2.2Gbps
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: Gigabit Ethernet
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: Ethernet
Protocol: Fast Ethernet
Antennas: [N/A]
Brand: NETGEAR
